Hotpoint WM52P brushes
  • #58959
    Pigpen4
    Machine had been in storage for 2 years and went “pop” when she turned it on.
    Replaced timer, brushes, heater and door interlock.
    It all worked OK when I left.
    Got a phone call later on, saying it wouldn’t spin.
    Went back to it, to find one of the brushes had welded its plastic casing round the carbon – it had got a bit hot!
    Re-checked insulation – still showing OL on my machine (>9999MOhms), and yes, I did check the leads to make sure they were in correctly.
    Resistance across motor pins of terminals is less than 8 ohms all around the armature.
    Replaced the brush, gave it lots of functioning, removed it and checked it again and it was still ok, refitted and functioned – still working fine.
    Phone rang at 9 last night – it’s not spinning again.
    Any ideas, please?
    #336300
    nelson
    Re: Hotpoint WM52P brushes
    Water pump a bit tired? :hmm:
    #336301
    allan73
    Ditto, gotta be the pump.
    #336302
    Pigpen4
    It pumps out ok, though – would this cause the carbon brush to weld, like it did?
    #336303
    The pumps can sieze intermittantly, especially when older, they are usually noisy when worn.
    If the pump is perfect then the armature is faulty.
    #336304
    Pigpen4 wrote:Went back to it, to find one of the brushes had welded its plastic casing round the carbon – it had got a bit hot!
    Yes indeed knackered armature for sure!
    #336305
    Pigpen4
    Many thanks – arm20’s ordered from Qualtex this afternoon.
    #336306
    Don’t forget to renew the pump though, or you’ll knacker the new armature for sure 😉 .
    Mike.
    #336307
    MickGeorge
    Had one of these a few years ago – changed armature etc. – turned out to be intermitant pump problem.
    Hotpoint allowed their machines to spin part/full of water for years !!! :rolls:
    Mick
