hotpoint wm53 and 63 motor
  • #68138
    deltra
    hi all, customer rang saying ,motor on his wm53 is u/s(says connecter block has 6 wires.i have found an old wm63 motor(800/1500rpm brown label) with 7 terminals 😕 so…. are these motors interchangeable ❓ if so which way does the connecter go ❓ what is the spare terminal for ❓ or am i going mad and barking up the wrong tree :eeek: :clown:
    #369975
    jimca007
    Re: hotpoint wm53 and 63 motor
    The extra wires a stator tap for the higher spins the old GEC motors ( the small kinda round things with the cartridge brushes) basically had two varients the large round taco type this was an analogue taco mainly used with lower spin upto 1000 rpm and the one with the smaller taco with the wee bar across it , this was a digital taco mainly in the higher spin machines. As far as I know the two types aren’t interchangeable as the signal type into the timer is different.The small taco 6 contact motor is interchangeable with the small taco 7 pin just make sure the taco wires are lined up and the rest fall in
    #369976
    deltra
    so,the old brown label motor should be ok. thanks very much
    #369977
    jimca007
    I usually use a black marker and mark the side of the motor plug where the taco wires are before unplugging the old motor then its easy to plug in the right way up ! This also works on the FHP motor which replaces the GEC type in older machines make sure the taco’s in the right place and you can push the plug in without any wiring alterations
