wm61p has lost all power,the owner says when she switched it on she saw a flash and everything stopped. on inspection i discovered a blown track on the timer,this was from the live to the door interlock.have solder repaired this track now and continuity restored,but still no power.
also discovered that the heater element has lost continuity.
is this linked? do i need to replace the door interlock and obviously the element, and is the timer ok.
the solder repair was straight-forward.
Any advice welcome.
P.S. power IS coming to the timer
