😕 I was wondering if any one has come across this? Went to the above machine and the timer had blown a couple of tracks as well as the 13amp fuse. done all usual earth checks and went through all components, everything checked ok.Fitted new timer assy and as soon as I switched it on bang!! blew the timer again. I disconnected the pump leads from the timer and metered it and it was a dead short across the terminals.of the pump.I thought I’d check everything again to be sure and then went back to the pump and this time it metered ok. 😕 I checked all wiring which all looked ok.
Any Idea’s
Merv
