Re: Hotpoint WM63 (programing not working)
hi there first washer could be a number of things bearings,weight,suspension,springs, uneven loads the list goes on should recomened an engineer to that one!
The second machine sounds like a blockage or the drain pump might of had it! very hard to say what it is without seeing machine but does sound like a drainage problem either way if you do decide to have a go at it remember REMOVE THE PLUG FIRST!
