Hotpoint WM64 Hinge Bearing Guide Screws Size/Type?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WM64 Hinge Bearing Guide Screws Size/Type?
  • #64985
    Danny27
    Hello all, New member here. I have a Hotpoint Aquarius 1200 WM64 with a broken hinge. I have the replacement hinge but I have lost the two screws / bolts that pass through the hinge bearing guides and clamp them to the outer door. Could someone tell me where I might get them (I have searched/Googled to no avail). Or if someone knows the size and type I’m sure I’ll be able to get them from a hardware shop. I just don’t want to take the chance on some that look like they fit but end up stripping the plastic thread. Thanks. Regards, Danny.
    #358729
    Re: Hotpoint WM64 Hinge Bearing Guide Screws Size/Type?
    i am assuming from your decription that the screws you have lost are the 2 screws that hold the 2 halves of the door together by the hinge securing the hinge bearings / pivots
    screws are nothing special just small self tap screw. there
    is another screw in the door frame that will be the same size use that as a guide
    Danny27
    Hi Dave. Yes, the screws missing are those that go through the hinge bearings. Thanks for the info. I didn’t realise they were just ordinary self-tappers. Many thanks. Regards Danny
    #358731
    just make sure thay are not too long otherwise they will break through the door skin
