Hotpoint wm64p. Wires & spade connectors for brushes
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint wm64p. Wires & spade connectors for brushes
  • #80179
    range1972
    our washing machine recently stopped working & when i checked the brushes i discovered that the connector on one side had completely melted and parted company with the wire. I have tried a few places online and cant find these. Does anyone know where i can source these from?
    I dont know if it makes a difference but the number on the motor is:
    904/1158/10
    RPM 800/1500
    TIA
    #412003
    Re: Hotpoint wm64p. Wires & spade connectors for brushes
    You just need to use the 2.8mm crimp spade terminals that most DIY, Hardware or Motor Factor Stores sell locally. Or look HERE
    Replace the brush assemblies too of course. 😉
    #412004
    range1972
    OK. Many thanks for your help. One other question: The last time i replaced the brushes the ones i bought said they were genuine Hotpoint ones but i have since read that genuine ones shouldn’t get so hot that the melt the connectors. Also they have only lasted about a year ( i know overloading the machine shortens the life of brushes & we are probably guilty of this).
    #412005
    The ‘high temperature’ laminated type of brush (genuine Hotpoint) are just as fallible to this problem. So pattern or genuine both can quickly overheat. One main reason for this is twofold, firstly, more often than not users of the machine do not allow the machine to rest between wash loads, so the motor gets red hot. Solution : Give a 10+ minutes break between wash loads to allow for cooling. Secondly, if the armature commutator is grooved through wear the brushes don’t seat fully and spark excessively. Solution, clean commutator with a ‘commutator bedding stick’ to smooth the segments like new again.
    HTH? 😀
    #412006
    range1972
    YEah that’s brilliant. Many thanks
