Here’s one!
Went to a Hpt WM72, flashes E15- check drain hoses. Checked – pumped out fine, no water left. No blockages in sump or hoses. Pressure switch seemed ok. No blockages in pressure chamber,hose or switch. Fills, washes, heats, pumps out, and then the error is reported.
Tried ( brand new from stock ) , control board, power board and even pressure switch. No better. Checked all associated wiring, ran wet test, no problem found. I’ve been doing this job 30 years, and this one isn’t going to get by!!
Anyone seen anything like it?
Bill 😥
