need advice got above machine displayin E16 which is normally water level checked pressure chamber and is clear and changed pressure switch but still does same pull in little bit of water than flashes up E16 and bleeps any other ideas b4 i throw it out
regards
Check the heater insulation if it is low it can cause this condition also check for slice marks on the heater due to bearing failure which will give the same fault , also if the hot and cold hoses are reversed you will get this also.
damn it been back today fitted new pressure switch still same fault,
pulls water in starts to rotate then starts to bleep and displays E16.
fitted new heater checked all hoses and wiring left off hose for pressure switch makes no differnce still bleeps at me,poxy thing any other ideas?
regards
tony
