Hotpoint WM73 bearing replacment
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WM73 bearing replacment
  • #13307
    wheelbarrow
    Hi Guys,
    This machine is about 8 years old and has never given me any trouble. Based on the information here and the black dust underneath the machine i need to replace the bearings.
    So i have ordered a set and will now be looking to take this on.
    Before i start is there anything else i should be aware of, i have plenty of time so i wont be rushing this. From what i can see i need to extarct the drum from the machine, seperate the inner and outer parts and then replace the 2 baerings. put it all back to gether and job done.
    So any helpful pointers before we start would be helpful.
    Thanks in advance
    Paul
    #154160
    Goatboy
    Re: Hotpoint WM73 bearing replacment
    :eeek:
    I hope you know what you’ve let yourself in for.
    Prepare to loose blood, sweat and tears.
    I’d check the heater for damage. I rarely do that job, and don’t replace the heater.
    Protect your hands and eyes, with gloves and goggles!
    And unplug the machine before attemping a repair.
    #154161
    If the dust is very black rather than a rusty colour then you may have a more serious problem. The alloy casting that the bearings fit into can on rare occasions come loose within the nylon drum. This leads to the black dust, the bearings usually cause a rusty stain on the floor/chassis. For very good legal and safety reasons we cannot go into blow by blow details of a bearing change, safe to say you will need a degree of mechanical competance and of course to do the job ‘correctly’ the correct tools to refit the bearings without damaging them. you should also replace the drum seal, if you don’t it will almost certainly leak.
    #154162
    wheelbarrow
    iadom wrote:If the dust is very black rather than a rusty colour then you may have a more serious problem. The alloy casting that the bearings fit into can on rare occasions come loose within the nylon drum. This leads to the black dust, the bearings usually cause a rusty stain on the floor/chassis. For very good legal and safety reasons we cannot go into blow by blow details of a bearing change, safe to say you will need a degree of mechanical competance and of course to do the job ‘correctly’ the correct tools to refit the bearings without damaging them. you should also replace the drum seal, if you don’t it will almost certainly leak.
    Ah, so if it isn’t the bearings that have gone what other parts may i need. i guess i’ll find out when i get the drum out.
    I wasn’t expecting a blow by blow account, but any pointers to easy extraction of the drum for example.
    Thanks for your reponce.
    Regards
    Paul
    #154163
    Goatboy
    wheelbarrow wrote:…guess i’ll find out when i get the drum out.
    Exactly! Strip in down first, then see what spares you need.
    Access, throught the front of the machine.
    Be Carefull!
    #154164
    If the alloy bearing housing is loose in the nylon outer drum you will see black marks around the housing at the back, you may even see a small crack all the way around the housing. New machine time if the housing is loose. Only cure is a new outer drum, around £120 for the part.
    #154165
    wheelbarrow
    iadom wrote:If the alloy bearing housing is loose in the nylon outer drum you will see black marks around the housing at the back, you may even see a small crack all the way around the housing. New machine time if the housing is loose. Only cure is a new outer drum, around £120 for the part.
    Thats ok then, i’ll assigned Thursday for this task, i’ll see how i get on. Thanks for all the responces.
    If the outer drum is broke then i have nothing to lose.
    Regards
    Paul
    #154166
    wheelbarrow
    Thanks for all your support, I have had the machine apart and replaced the bearings, the inner one had completly disintergrated. So much so that once the repament had been installed it was no longer a tight fit.
    Put the whole machine back together and run it on a test wash but it still seemed to rubblem and knock on a spin so i guess it’s time for a replacement.
    Looking at the hotpoint wt960.
    Once again thanks for the support.
    Regards
    Paul
    #154167
    Don’t. Go and look at the Bosch range.
    johnnyj
    I have a hotpoint wf860p for a year and a bit been great, married 22 years 3 machines and all still running sweet as a nut, old dear down the road got my old 95492a when i picked up a wm22w that someone was putting out due to new kitchen hads that for ages my pal who seperated from his missus gave him it and expect this to be as good
    #154169
    johnnyj wrote:I have a hotpoint wf860p for a year and a bit been great, married 22 years 3 machines and all still running sweet as a nut, old dear down the road got my old 95492a when i picked up a wm22w that someone was putting out due to new kitchen hads that for ages my pal who seperated from his missus gave him it and expect this to be as good
    Great expectations, but misplaced I’m afraid.
    If you allow for the fact that Hotpoint are now owned by Indesit and some of Indesit’s troublesome electronics have already crept into the Hotpoint machines, then Penguin 45’s advice is very sound. I have a customer with a 27 year old Hotpoint, the current machines will be lucky to see 7 years 😥
    #154170
    andy2
    iadom wrote: Great expectations, but misplaced I’m afraid.
    Iadom – Seven years would be more of a ‘miracle’ than ‘luck’ 😆
    Andy 😀
