Hotpoint WM75
  • #50950
    rocker
    Customer tells me this machine is in a rented flat, girls sharing, clothers are being ripped on occasions…a week ago another engineer called and advised them not to overload ect, same advice as I woud give, they tell me the loads are lighter but still happening,..the landlord wants me to call to find fault, I fell I am wasting my time and his money. as bearings/door boot ect appear to be ok, can anyone let me know if I am missing something.
    cheers John
    #306422
    A1TEC
    Re: Hotpoint WM75
    What about drum paddles,are they loose or worn? or any chance of bra wire popping through drum from time to time.?
    John.
    #306423
    spimps
    Re: Hotpoint WM75
    Bra wires a favourite poking up through the drum now and again.
    Splits in drum,raised holes from coins pushing the drum inwards causing sharps.
    Run your flat hand all around the inner drum and also press firmly where sides join in case of split.
    Shine a torch through the holes towards heater position and you can usually see any foreign objects.
    #306424
    rocker
    Re: Hotpoint WM75
    Thanks gents for your advice, will check these out. John
