Hotpoint wm76
  • #18100
    bigkid
    Hi, anyone know the test procedure for this model range. Neglected to get a service manual when they were cheap and available.
    Tony
    #177703
    DAZ123
    Re: Hotpoint wm76
    hold in a+c(wet test) or a+d(spin test) and turn on then press start
    #177704
    bigkid
    Re: Hotpoint wm76
    Ta Daz, any “last known fault” etc
    Tony
    #177705
    Re: Hotpoint wm76
    No last error info on these, other than the fault codes already listed in the ‘Known Error codes’ thread.
    Are you having a specific problem Tony?
    jim.
    #177706
    bigkid
    Re: Hotpoint wm76
    Not as such Jim but came across one the other day that just sticks “sometimes” at the end of the spin + “sometimes” during the rinses. A bit vague from the customer and wouldnt do it for me. Thanks anyway, wIll let you know.
    Tony
    #177707
    PGS
    Re: Hotpoint wm76
    Stick a pump on Tony
    #177708
    Re: Hotpoint wm76
    It should be giving error messages if pump had jammed though, worth a try all the same.
