HOTPOINT WMA 10 NO SPIN
Viewing 15 posts - 1 through 15 (of 20 total)
  • #15076
    jag-12
    Hotpoint wma10 will not spin with a load in it,spins fine empty.
    Have changed module and motor but has not made any difference.All wiring checked can see no damage or bad connections.Goes right through cycle but does not spin.No problems empty spins up to full speed but put in a dry shirt and no spin 😕
    Any ideas as think I have another one with the same problem to look at later in the week 😮
    #161918
    Re: HOTPOINT WMA 10 NO SPIN
    Strange one, might be worth changing the motor to module harness, part number 1603396, it is only a few pounds and should eliminate any possible bad contacts. I always carry one.
    Do you get any of the option lights flashing when it malfunctions?
    #161919
    jag-12
    No lights flashing just finishes cycle as normal but no spin.Have a spare harness from scrap machine so will give it a try.Just that it works fine empty which suggests some kind of out of balance fault. 😕
    #161920
    SDR
    could be blocked pressure chamber or split in pressure hose, blocked sump?? 🙂
    #161921
    jag-12
    Run with load no spin, turn off at mains( to preserve program) open door,remove load, spins. 😕 Repeat and replace load no spin!!!
    Run up empty with door open spins fine .Throw in a load and it stays spinning 🙄
    #161922
    bobokines
    This sounds the same as the Servis problem with stretched belt… I have not seen this on a Hotpoint though.
    Bob
    #161923
    Simon46
    Just one garment? have you tried a half full drum load?
    S.
    #161924
    Seamy
    Sounds like the unbalanced load scenario doesn’t it. The machine won’t go into spin but will keep trying to distribute the load.
    #161925
    jag-12
    Doesnt matter what size the load it just wont spin,only takes a single light item to stop it.Seems to be that system is sensing load is out of balance and tries to rebalance but have replaced motor and module with ones out of working machine.Still the same.It has become personal now 😡
    #161926
    Dave_Conway
    Has the belt been replaced with a pattern one by any chance ? 😉
    #161927
    jag-12
    First time machine has gone wrong since purchased.
    #161928
    If you have changed the motor and module, the only other component directly involved in the spin process is the level switch……..
    VillageIdiot2
    Blocked
    Got to be the OOB (out of balance) surely? If it spins every atempt with an empty load and there are no fault codes, that indicates the compnents are all working fine………maybe dodgy motor………reading unbalanced load everytime there is something in the drum even tho the load maybe perfectly ok? I would have to try another motor personally……..very odd, I look forward to reading the cure!
    #161930
    Martin114
    Bit of a long shot, but what about the RF suppressor?.
    Not had this problem on a wma, but used to get problems with the old servis quartz – computer resetting when ramping up to spin under load!
    #161931
    wilf
    check wires on the right end of mod one to heater one to p/sw had a similar fault customer had fiddled about and got them mixed up I think its insulated to the outside but check first
    wilf
