HOTPOINT WMA 10 NO SPIN
Viewing 5 posts - 16 through 20 (of 20 total)
  • #161932
    bobokines
    Re: HOTPOINT WMA 10 NO SPIN
    Warped pulley?
    Bob
    #161933
    jag-12
    Fixed It 😀
    Changed hot water valve now it works just the way it should.No idea why but with old valve put back in it refused to spin again 😕
    #161934
    To quote Marlon, from the Perishers, the mind boggles. 😯
    I feel a Victor Melldrew moment coming on. 🙂
    I for one would be very interested in any hypothesis on this. ❓
    What made you change the hot valve, what is the resistance/insulation reading on the displaced valve. Can you save the valve and put it in another machine to see if you can replicate the fault?
    #161935
    jag-12
    Changed the hot valve cos i was changing everything, part by part in desperation,and a refusal to be defeated by this ***** machine.
    Only thing susect about it was a slightly low insulation resistance 5meg.
    Electronics dont you just lov em 😆
    #161936
    jag-12 wrote:Only thing susect about it was a slightly low insulation resistance 5meg
    Hold up!
    5 MEG ???
    What is causing this earth leak I wonder, ‘cos sure as hell the Module won’t play ball with that I reckon 😉
