Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WMA
- This topic has 12 replies, 6 voices, and was last updated 15 years, 4 months ago by
waters.
December 2, 2010 at 5:51 am #59295
waters
ParticipantIs there any fix for a wma with the heater locator missing.Seems like scrap or new rear half but just checking
December 2, 2010 at 7:20 am #337596Allsorts
ParticipantRe: Hotpoint WMA
What do you mean by ‘Heater locator’?
George
December 2, 2010 at 8:00 am #337597Phidom
It’s a very short heater so should probably be OK without support for the hot end.
December 2, 2010 at 8:52 am #337598Martin
waters wrote:Is there any fix for a wma with the heater locator missing.
The “heater locator” is referred to by Hotpoint as a ‘Heater Bracket’ (Pt No. C00112690) and clips onto the heating element prior to locating it into position. If that bracket is “missing” it must have fallen off somewhere inside the drum I guess? Slide out one of the drum lifters to search for it, I would. 😉
December 2, 2010 at 10:14 am #337599waters
No sorry i mean the drum ,where the heater sits under
December 2, 2010 at 12:35 pm #337600leavemetogetonwithit
Don’t know if molding gives room to cut slot in a bit further back and then use longer / extended heater bracket? If so you might be able to cut slot using hot piece of metal / modified solder iron and “heater hole surgery”.
Mike.December 2, 2010 at 1:09 pm #337601Martin
waters wrote:No sorry i mean the drum ,where the heater sits under
Errr, hold up! You’re confusing me on this (don’t take much by the way.:rolls:) The heater bracket is fixed to the heater prior to inserting it in place. Are you with me so far? Now, that heater bracket protrudes beyond the actual length of the heater, the end of which slides under the front drum moulding, thus holding it in place. So based on that fact do please explain where your problem ‘sits’….???(please forgive the pun by the way – can’t help myself sometimes. 😈 )
leavemetogetonwithit wrote:Don’t know if molding gives room to cut slot in a bit further back and then use longer / extended heater bracket? If so you might be able to cut slot using hot piece of metal / modified solder iron and “heater hole surgery”.
That’s got to be this month’s HOT tip for darn sure…..what are you like Mike? 😀
December 2, 2010 at 3:40 pm #337602iadom
ModeratorRe: Hotpoint WMA
Its obvious, he means the moulded lug on the inside of the drum the the heater clamp slides under has broken off. Simples. 😀
December 2, 2010 at 3:44 pm #337603Allsorts
If he is talking about the heater locating lug which is part of the drum, which I think he is. If he is using the short heater surely by removing the Heater Locator from the heater everything should be ok so long as the mounting side is secured properly and there are no cracks around where the lug broke off.
George
December 2, 2010 at 3:51 pm #337604iadom
Not always the case. If the lug has been broken off then this customer is one who doesn’t check pockets etc. They don’t change in spite of how much you tell them.
If the loose heater gets hit by a coin etc and bent it can easily start to hit the drum.
The old brass heater bollard would have been ideal but I did once repair an old WM drum by drilling a hole in the drum and then using a non ferrous bolt, metal and rubber washers and two nuts fashion a heater bollard that lasted for another ten years.
A fix that even Mike would have been proud of. 😆
December 2, 2010 at 4:03 pm #337605leavemetogetonwithit
iadom wrote:
I did once repair an old WM drum by drilling a hole in the drum and then using a non ferrous bolt, metal and rubber washers and two nuts fashion a heater bollard that lasted for another ten years.Jim.
Excellent work, Jim!I had a situation like this on an old 95 series once. Took me ages to figure out where the tapping noise on spin was coming from. Can’t remember how, but I did fix it.
Mike.December 2, 2010 at 4:16 pm #337606Martin
You could always fit a Zanussi 1247825100 Heater fixing spring come to that then without drilling holes through the tub, a self tapper will suffice!
If needs must that is? 💡
December 2, 2010 at 4:29 pm #337607waters
Thanks,i will try removing the heater locator
