Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint – Wma 31n
- This topic has 11 replies, 8 voices, and was last updated 19 years, 6 months ago by
brett1611.
September 22, 2006 at 10:34 am #21056
brett1611
ParticipantHi Again — On every prog selected all that happens is the door lock light flashes + it won’t start. I’ve tried several interlocks and a top pcb. It needed a config doing which another eng in the firm did while I was out but still it does the same thing >> Any Ideas
September 22, 2006 at 10:41 am #189310DDSDDS
ParticipantRe: Hotpoint – Wma 31n
the wiring between them, i would try a new pcb again i have never come across one that was anything other than door lock or pcb or more frequently both.
let me know how you get on though.
does the door pin work properly??September 22, 2006 at 3:20 pm #189311Bryan
DDSDDS wrote:i have never come across one that was anything other than door lock or pcb or more frequently both.
Strange , I often find faulty motor blowing PCB on WMA`s :idea:.
Might be worth checking anyway.
Bryan
September 22, 2006 at 3:26 pm #189312Martin
….and to add to Bryans experiences….the wiring loom around the counterweight shorting to earth 😉
September 22, 2006 at 4:54 pm #189313DDSDDS
just to clarify i was talking about the flashing light i have only seen door locks and boards fail that cause that.
but i have also seen scraped wires on the base blow the board although i have never come across a wma with a faulty motor yet although evryone else seems to have just lucky eh
September 22, 2006 at 5:27 pm #189314johnnyj
The Bosch motor when brushes wear down take out the board about 70{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time
September 22, 2006 at 5:44 pm #189315Bryan
Now who`ll be to blame for that johnny , the Bosch motor or the Merloni electronics :?:……..mmmm I wonder :rolls:.
Bryan
September 22, 2006 at 5:56 pm #189316bobokines
Bryan wrote:Now who`ll be to blame for that johnny , the Bosch motor or the Merloni electronics :?:……..mmmm I wonder :rolls:.
Bryan
I recon it’s the Bosch motor. I have often had Bosch machines where the brushes wear down below the tamping on the brush (allowing the pigtail to damage the commutator). I can’t honestly remember seeing any other make of motor where the brush does not captivate early enough to stop this kind of damage.
Thumbs down to Bosch in this area.
Bob
September 22, 2006 at 7:15 pm #189317Bryan
Hi Bob , I suppose we`re going a bit off topic here but I generally find that the commutator cleans up nicely with a comm stick on Bosch motors and with new brushes fitted there`s no problem. Occasionally might need a new end cap if the cut out has gone but hardly ever damage to PCB.
I seem to remember you not liking the use of comm sticks but it always seems to work for me on Bosch motors. I take your point that the motor/brush fault is causing the PCB damage so perhaps it`s just a case of poor quality motor and poor quality electronics.
Bryan
September 22, 2006 at 8:24 pm #189318johnnyj
BryanWMA’S dont use Merloni electronics they are made by AKO who i believe are a subsidary of Bosch.
September 22, 2006 at 10:40 pm #189319iadom
ModeratorRe: Hotpoint – Wma 31n
Have to agree with all of the above, the Bosch motor is the one that causes most problems on WMA PCB’s without a doubt.
September 25, 2006 at 8:39 pm #189320phil59
Participantive had the exact same prob with bad connections to front panel,taken plugs off and straightened connectors every thing ok after that
