got a problem with this machine initialy two cables on the motor plug had shorted i repaired this and the machine ran fine until the final spin it completes this goes on to the tumble at the end and then cuts out the led light stays on spin and does not change over to end so the door remains locked so far i have tried a board from Emw, a new door interlock ,another motor, pressure switch and changed the loom from board motor and lock but still the problem remains and im running out of ideas hoping somebody can help or has a wiring diagram for this model thanks cras
