hotpoint wma 74 door lock
  • #58961
    funbobby
    going later today and door light is flashing, is this likely to be module, interlock or a bit of both?!
    #336308
    Re: hotpoint wma 74 door lock
    Check door latch spring, if OK try a door lock, if it still doesn’t work then the PCB is faulty.
    Had the exact same fault on a WMA20 this morning, small hole in door seal, leaked onto door lock. No visible signs of damage but had to change the PCB as well as seal and lock to cure fault.
    Nice start to the day. 8)
