Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WMA Door Seal Clamp
- This topic has 8 replies, 8 voices, and was last updated 18 years, 1 month ago by
spanner51.
February 12, 2008 at 7:32 pm #34555
spanner51
ParticipantI changed a WMA door seal today. The clamp was the new type with the hooks on a ratchet. How on earth are you supposed to tighten it? Is there a special tool? Any suggestions appreaciated.
February 12, 2008 at 8:26 pm #243109indespoint
ParticipantRe: Hotpoint WMA Door Seal Clamp
I tend to use a pair of pliers to hold one end and a screwdriver then to tighten the band up.
They are a pain to tighten and thats from someone who works for indesit.February 12, 2008 at 8:30 pm #243110iadom
ModeratorRe: Hotpoint WMA Door Seal Clamp
I don’t find those clamps on Hotpoint machines much bother, usually use long nosed pliers, its the ones on the Indesit machines with the full wrap round cabinet that are a PITA. I have a pair of hook nosed pliers for them.
February 12, 2008 at 8:38 pm #243111richardable
jims your man, long nosed pliers do the job.
richardFebruary 13, 2008 at 8:26 am #243112eastlmark
richardable wrote:jims your man, long nosed pliers do the job.
richarduntil they snap off! Cannot belive Indesit do not have a specific tool for these. I assemble them quite tightly and stretch them on then pinch up with the pliers. As Jim said, not so easy on the Indesit versions.
February 13, 2008 at 8:54 am #243113Martin
Yes they’re quite simple to compress using long nose pliers. And made even simpler if you use a little washing-up liquid and water around the door boot lip first! 😉
Nice and slippy does it 😆
February 13, 2008 at 7:41 pm #243114spanner51
Thanks for all the replies. The idea of using washing up liquid sounds a good un.
However, the seal I used ( a genuine Hotpoint one ) was covered in some sort of mineral oil, maybe to assist fitting.
February 13, 2008 at 8:19 pm #243115lerch
All above good ideas but personally never had any problems usually 15-20 minutes in out and tested. I use small flat blade to unclip and long nose pilers to tighten up 😀
February 13, 2008 at 9:27 pm #243116hotpnt
the best ones to get are bent long nose pliers, you get more pressure, there is a hopoint tool for it but it breaks after a few uses!!
