Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint wma drum
- This topic has 7 replies, 5 voices, and was last updated 18 years ago by
simonb.
April 10, 2008 at 4:29 am #35910
simonb
Participanthello all
Hotpoint wma drum usual split drum think model number is wma32
the drum is jammed up and sometimes releases going clockwise if its pushed round, first i though usual beaing failure but when it releases it spins round a few times with no noise at all, then restriction again, its stuck with something but theres no noise at all nothing metallic frees up the gets stuck again if you get the picture?any ideas? ould there be something jamming in up? iv checked the rim between drum and tub for any ballbearings as iv come across this on a zanussi few times were a kid manages to get something in the rim and its stick, i cant feel anything there or see anything
anyway ill stop waffling
later
simonbApril 10, 2008 at 7:02 am #248701Dales-Electronic
ModeratorRe: Hotpoint wma drum
These early WMAs are renowned for bearing problems, Id put it on its back, pull off the sump hose, remove the heater and see if you can see an obstruction (ie a sock) stuck between outer and inner tub
April 10, 2008 at 7:12 am #248702Martin
ParticipantRe: Hotpoint wma drum
…..or take one of the drum paddles off and take a gander inside? 😉
April 10, 2008 at 10:22 am #248703iadom
The only way to be certain is to open the patient up. I have had several instances of coins etc getting stuck between the drum spider and the drum itself. Had one WD420 that they managed to get a 20p coin stuck like this, nice little earner for full strip down, blow me three weeks later I’m back , this time it is a large disc type earing stuck in exactly the same place. :rolls:
Also had to strip one down for a sock behind the drum a couple of weeks ago, just as Ian mentioned.
You would not be able to see any of these by removing the lifters or heater.
April 10, 2008 at 10:39 am #248704simonb
Great Tips Guys i never thought of taking a paddle off! Ill go back and have a look today
my memory saying iv seen the same thing before with the way the drums freeing up and then getting stuck!Simon
April 10, 2008 at 4:16 pm #248705leavemetogetonwithit
Been to a WD420 this morning which had same problem. Took out half offending rag via paddle hole but still something invisible is causing a jam. Please somebody come up with a clever fix to avoid necessity of total stripdown (machine in horrible corner of cluttered flat). What about if I took off the dryer manifold? Could I fish around from there?
Mike.April 10, 2008 at 4:37 pm #248706iadom
You could always revert to your method with Bosch motor mounting bolts, drill a hole through the back. 😆
April 14, 2008 at 4:17 pm #248707leavemetogetonwithit
leavemetogetonwithit wrote:What about if I took off the dryer manifold? Could I fish around from there?
Mike.New drum paddles arrived and went back today. Can’t believe how easy it was. Five screws hold the dryer assembly to the top of the drum and they all face up at you so you can get at them easily. Move the assembly aside, take out a little filter thing and you have a perfectly placed access opening to get at the back of the drum. Turned the drum round half a turn and there was that sock staring at me. No need for the curtain wire and hook I’d brought with me. Just pull it out with the long nosed pliers.
Ten minute job.
Mike. -
