Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WMA Washer draining problem
- This topic has 8 replies, 6 voices, and was last updated 18 years, 5 months ago by
johnnyhoz.
October 27, 2007 at 1:35 pm #31732
johnnyhoz
ParticipantHi All
had this one today that has a draiing problem, with the water in the drum the pump sounds empty and does not drain at first but after a minute or so it does. Fitted new pump made sure all the hoses were clear a looked for any obstuctions though the sump hose connection and tried again but same as before, removed sump hose again removed float ball but still the same, apart from something floating around in the drum has anybody got any ideas please
John
October 27, 2007 at 2:15 pm #232330Simon46
ParticipantRe: Hotpoint WMA Washer draining problem
To spigot or standpipe?
How does it empty into bucket?S.
October 27, 2007 at 3:01 pm #232331johnnyhoz
Hi Simon,
It’s to a spigot, havn’t tried it into a bucket
John
October 27, 2007 at 3:03 pm #232332silverbroom
Was at a H/P WT741 to day, not draining. Through door glass could see the dreaded bath and floor mat, anyway remove machine from under worktop and on further inspection found no blockage whatsoever.
Looking at drain hose where it goes through side hole in unit found hose to be squashed flat due to machine being pushed back against it.
Once repaired pump drained no prob, have had this before but bath mats made me start looking in pump and sump area.
If machine drains into waste pipe via spiggot take this off and check for blockage have found 5p in here before.
silverbroom
October 27, 2007 at 3:15 pm #232333Simon46
5p or uphill waste plumbing i would say.
S.
October 27, 2007 at 3:20 pm #232334johnnyhoz
When I first got to the machine I checked the spigot and found it was almost totally blocked but the pump still didn’t drain imeadiatley after that, there was still a minutes or two when the pump sounded empty then it started to pump the water out.
John
October 29, 2007 at 6:26 pm #232335JOHN CLARKE
Had this problem once while I worked for Hotpoint, found the corrugated hose to pump from filter needed adjusting (re-aligning) it seemed to be forming an air lock somehow. Hope this helps, long shot but try it.October 29, 2007 at 8:31 pm #232336roy1
Have you removed the pump non return flap, they can cause a problem.
October 30, 2007 at 8:20 pm #232337edthespiv
i once had this problem. the customer had used a “colour run” sheet which was like “bounce” sheet used in T/D’s. It was floating around in the drum.
