hotpoint wma11
  • #13724
    hilly
    i replaced carbons about a week ago and customer called me back because on a long wash it smelt of burning ive checked everything all ok then i cleaned the com just incase now all the machine will do is drain for about a minuite. it wont reset, ive checked all components and connections. any ideas?
    thanks paul
    #156300
    Re: hotpoint wma11
    Chafed wiring loom? Motor TOC?
    #156301
    nigegt
    Re: hotpoint wma11
    Hi paul
    Have come across similar problem after brush change, appliance failed again after about a week with burning smell and it had blown some tracking on the control pcb where the motor connector is. It appears it was allmost burnt out when the brushes where worn and managed to work for a week after before packing up alltogether!, re soldered and all ok no come back but always check for it now as a very annoying recall!!
    Nige
    #156302
    technics1200
    Re: hotpoint wma11
    I used to WD-40 the Comm, clean it up, wait for dry then change brushes.
    Slow but works 😥
    #156303
    hilly
    Re: hotpoint wma11
    thanks for advice found out it was a motor fault
    thanks paul
