hpt wma 30 july 2000.
put machine on any wash prog. ie c,d etc. machine fills to correct level,with an occasional “pulse” from the pump,then when filled it will starts to wash for a few minutes then the pump is “pulsing” all the time,swithing on and off all the time for a few seconds at a time.
no shorts on pump cables,no tracks on pcb burned,machine insulation resistance is ok.no control panel lights flashing.
what do you think guys?control panel,pressure switch maybe?
john
