have got a wma30 with the following results when i have done the test procedure on it ,the four leds are 1,off,2,on,3,flashing and 4,off.
the END led does not light up on machine and door lock light flashes on trying to start any programme ,though door interlock has been changed with no success.Can anyone point us in the right direction to go next thanks
If the door lock light is still flashing after new one fitted and the spring in the latch is OK then its almost certain the old doorlock has damaged the PCB.
look very closely at the small triacs, you may find one missing a small piece from the corner.
Replaced the door lock and replaced pcb with another known good one and still comes up with same error code as before !! ,machine will wash but won’t go into spin mode have changed the brushes (old ones were worn ) but still won’t spin fast any further suggestions anyone ?
Make sure you observe the correct light sequence, the ones you mention in your first post are nothing at all to do with any errors. The four option lights along the top, centre do not show error codes. The Final Spin light is the only one used for the last known error.
Could be a sticking pressure switch or partially blocked sump or clogged pressure chamber.
