Hotpoint WMA31
  • #15978
    PGS
    Hi has anyone got a control board configuration leaflet for the above machine or is it the same as any other model as i have leaflets for WMA34 uptoWMA 58 cheers guys. A copy would be much appreciated Paul.
    #167056
    Re: Hotpoint WMA31
    Moved to Trade Tech. 😉
    I am almost certain I have a sheet for those, not the same as the ones you mentioned. Will dig it out and e-mail you later, after I have had my tea. 🙂
    #167057
    Re: Hotpoint WMA31
    Paul, check your e-mails. 😉
    PGS
    Re: Hotpoint WMA31
    Thanx for info, Have you ever come accross a wma62 that wont heat although it goes through progs ok and the only way to get door open is to switch off at socket outlet. Got me puzzled ,probably the power board but thought id ask cheers Paul.
    #167059
    PGS
    Re: Hotpoint WMA31
    PS ive checked continuity to heater from press s/w and board and changed the thermister
    #167060
    johnnyj
    Re: Hotpoint WMA31
    Wma’s if there is no temp rise detected it will carry on and and finish programe, so if the heater and wiring test okay has to be a module fault i’m afraid.
