Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › hotpoint wma31
- This topic has 3 replies, 3 voices, and was last updated 17 years, 6 months ago by
spuzzer.
September 17, 2008 at 9:19 am #39538
spuzzer
Participanthi can anyone help we have a customer with a hotpoint wma31 the fault is it starts any programme then after about 10 mins it shuts down and the wash light and also the rinse/spin and the final spin lights come on and nothing else its going to be nightmare too get the machine out of where its fitted so any help would be great.
September 17, 2008 at 10:33 am #262736iadom
ModeratorRe: hotpoint wma31
This information is in the Known Error codes thread.
Might be worth running it through this first.
Hotpoint WMA 30/40/50 LAST ERROR DETECTED codes
Ensure that the main selector switch is in the Off or O position.
Press and hold the Super Rinse and Rinse Hold buttons whilst selecting H on the selector knob, and continue to hold for five seconds.
The ‘Super Rinse’, ‘Rinse Hold’ and ‘Wash’ LED’s will now be flashing.
Press the Start/Cancel button for two seconds.
The ‘Rinse Hold’ LED will be lit and the ‘Super Rinse’ LED will be flashing.
The ‘Final Spin’ LED could be on or off at this stage.Press the Rinse Hold button briefly.
The ‘Rinse Hold’ LED will be flashing & the ‘Super Rinse’ LED will be on steady to indicate the last error routine has been initiated.
Rotate the main programme selector knob slowly anti-clockwise to programme A
Slowly rotate the selector switch clockwise through four positions A to D inclusive, pausing briefly at each programme position. Starting with A make a note of the ‘Final Spin’ LED status. it will be on or off.
When the selector knob reaches D you will have a series of Ons and Offs . This 4 bit binary code should be recorded and checked against the error codes in the following table.
……………………………………………………..A………..B………….C………..D
No spin due to O.O.B……………………….on………off………..off………off
Start butt pressed with door open…….off……….on…………off……..off
or O/C interlock.Failure to fill in allotted time……………..on……….on……….off……….off
Failure to pump out in time allowed……off………off………on……….off
No feedback from thermistor when……off………on……….on………off
heating.Tacho error…………………………………….on……..on……….on………..off
No feedback from tacho…………………..off……….off………off……….on
Motor O/CMotor triac short circuit…………………….on……….off……….off……….on
September 17, 2008 at 1:08 pm #262737spuzzer
ParticipantRe: hotpoint wma31
many thanks..spuzzer
Edited your post for you, 😉
September 17, 2008 at 7:15 pm #262738grazzamongrel
dude when the 3 lighrs come on it indicates “a major fault”. having been a hotpoint engineer and have come across this fault many times the only way to rectify this fault is a new motor and control module.had the same fault on my own appliance and as i said this is the only guaranteed fix.
grazza
