Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint WMA31
- This topic has 8 replies, 6 voices, and was last updated 17 years, 2 months ago by
mike100.
February 6, 2009 at 7:08 pm #43218
mike100
ParticipantThis washer in an outhouse where after the freeze one of the pipes burst and apparently sprayed water over it.
Then all it would do is the door lock light flashed.
I tryed a new interlock and it was the same.
Then I put in an identical board Part No.1604321 and it all worked immeadiately.
Got a call back next day, she didn’t know when but it had stopped in mid cycle full of water and door light flashing again.
I checked brushes they are ok.
Has the board gone again or am I missing something.
Any help appreciated thanks.
MikeFebruary 6, 2009 at 7:13 pm #276460kiddo66
ParticipantRe: Hotpoint WMA31
Did you programme the board up for that machine?
February 7, 2009 at 8:22 pm #276461mike100
I didn’t think it was necessary as it was an identical to the replacement.
Also it worked ok as soon as I fitted new one.
any other ideas .
thanks,MikeFebruary 7, 2009 at 8:50 pm #276462Turbo
Sure you would have had to programme that board, was there not an instruction sheet supplied?
GrahamFebruary 8, 2009 at 12:03 am #276463iadom
ModeratorRe: Hotpoint WMA31
mike100 wrote:
I didn’t think it was necessary as it was an identical to the replacement.That board fits at least 16 different models, if you don’t have the config codes I can let you have them.
February 8, 2009 at 8:46 am #276464dpr1974
Hi Jim, is it possible to get a copy of those config codes?, i don’t need them yet but it would be great to have the information ready when i do. ThanksDavid
February 8, 2009 at 3:06 pm #276465iadom
Sent you what I have. 🙂
February 8, 2009 at 5:54 pm #276466mike100
Hi guys,
Yes I do have the configuration codes. I just thought that having fitted the same board it would be ok as it started alright. Now it stopped full of water and door lock started flashing again.
I will go back and see if it will let me configure.
Cheers MikeFebruary 10, 2009 at 6:35 pm #276467Andystu
Without stating the obvious.!!, did you put the old interlock back on or leave the new one on?. These interlocks as you probably know are great for blowing the boards, so always prudent to fit new interlock anyway.
Andy Stu
