Re: Hotpoint WMA32
Two wires with AMP tags, sheathed wire from heater to first terminal from the right looking from the front, other wire on terminal next to it goes to pressure switch.
Small square block goes into selector switch, should only fit one way.
Bottom edge from the right, 10 tag block onto X1. six tag block onto X5, two tag to pump next to this, two tag to pressure switch next to this, both of these on X9. On some machines this can be a complete block. Two tag block to thermistor to X2, small 4 tag connector to variable controls, X4.
HTH.
