Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WMA32 – door will not open
- This topic has 4 replies, 2 voices, and was last updated 17 years, 7 months ago by
DamonFisher.
August 31, 2008 at 3:09 pm #39110
DamonFisher
ParticipantHi
Sadly I find myself back on your excellent forum for help and advice. This time with our washing machine. (Thanx again for all the help/advice and supplying the parts to fix our Smeg range) 🙂
The problem is with our Hotpoint WMA32 washing machine. It has just finished a normal wash on program “E” and will not allow the door to be opened.
The “end” light is NOT lit.
The “door locked” light IS lit.I am unable to get the door open by holding the “re-set” button.
Many thanks in advance 🙂
August 31, 2008 at 3:20 pm #261327iadom
ModeratorRe: Hotpoint WMA32 – door will not open
Has the machine emptied completely?
Switch off at the mains and then wait a few minutes, if the door opens but you still have some water in the drum then you may have a blockage in the sump hose/filter assembly.
If the door will not open then it may be the door lock itself that has failed.
EDIT. moved from dishwasher forum to washing machine forum, I assume you don’t wash your pots in this machine. 😉
September 2, 2008 at 12:51 pm #261328DamonFisher
ParticipantRe: Hotpoint WMA32 – door will not open
(Cheers for moving the thread – sorry I put it in the wrong place)
The machine is completely empty – I’ve since done a rinse & spin, it empties fine but the door is stuck shut! 🙁
September 2, 2008 at 3:47 pm #261329iadom
Have you isolated the machine completely from the mains, if you have and the door will still not open then the door lock or handle is faulty.
I changed a doorlock this afternoon with this exact fault and have another one to do tomorrow.
If you feel up to it, THIS is the part you may need.
You will need to unplug the machine, take off the top and reach down and waggle or bend the old one to release it.
September 2, 2008 at 4:43 pm #261330DamonFisher
I’ve unplugged it completely from the mains for about 15 mins but the door is still stuck.
I guess I’m gonna have to go inside now! 🙁
Cheers for the advice 🙂
