Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint wma32 module config
- This topic has 8 replies, 4 voices, and was last updated 18 years, 11 months ago by
DPDOM.
April 17, 2007 at 2:09 pm #26673
DPDOM
ParticipantHi Chaps
Can anyone tell me how to configure the above module as the new one did not come with the instruction sheet and I can’t remember.
Cheers
DaveApril 17, 2007 at 3:29 pm #210995admin
KeymasterRe: Hotpoint wma32 module config
Im no expert but didnt realise they needed configuring?
Ive only ever replace like for like whether new or recon!
Maybe ive been lucky……LOLCol
April 17, 2007 at 3:39 pm #210996hotpnt
ParticipantRe: Hotpoint wma32 module config
Hi the programming for a WMA32 is as follows
Switch to OFF
Press & Hold ‘Super rinse’ & ‘Rinse Hold’ whilst turning dial to ‘K’
continue to hold for 5 secs untill ‘super rinse’, ‘rinse hold’ & ‘rinse & spin’ flash
Press ‘start’ for 2 seconds, all led’s go outthen for WMA32 turn dial back to ‘D’ press start, (super rinse led lights)
turn dial to ‘A’ press start, (rinse hold lights)
keep dial at ‘A’ press start again (super rinse & rinse hold light)
turn dial to ‘E’ press start, (rinse hold led on, super rinse led flashes)rotate back to ‘A’ then turn through all settings, Final Spin light should go as follows for each dial position
on,on,off,off,off,on,on,on,off,on,off,on,off,on,offApril 17, 2007 at 4:12 pm #210997admin
ok now im worried….LOL!!!
Ive never configured one of these before
and just checked cause I fitted 4 last year!!
Probably because of door interlock failures
(they were all new boards)
What does the configuring do?
why have I not needed to do it?Just to ease my worry slightly…….Col
April 17, 2007 at 4:18 pm #210998hotpnt
unless you ordered them pre-programmed one board can fit about 12 machines so need to be set up to fit the programmes on the machine its being fitted to, i wouldnt worry, if they were wrong you would have found out the next day 😉
April 17, 2007 at 4:25 pm #210999admin
Ah yes that makes sense…..yes always just
ordered direct replacement…..
OK I can sleep again now….LOLThanks Col
PS is there a larger profit margin for me ordering
a more universal board then?April 17, 2007 at 6:57 pm #211000DPDOM
Thanks hotpnt
Your a star
DaveApril 17, 2007 at 7:00 pm #211001iadom
ModeratorRe: Hotpoint wma32 module config
Almost all WMA boards need configuring, the instructions for doing this are usually in the box, the V20 board for the WMA32 fits seven or eight different models. I find it strange that you have had four modules and none of them had configuration instructions in the box, assuming they came from a kosher supplier of course. 😉
April 17, 2007 at 7:13 pm #211002admin
Yes seriously never seen any instructions!!!
Also only source from Connect or Europart I assume they are kosher!!LOL
until recently when I actually sent a few off for repair
instead of new…..so Im amazed as well…..Most worrying thing is im finding out so much I dont know since joining
this site!!! Been repairing for 5 years now cant understand how Im
still here…LOL -
