Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WMA33 bearing
- This topic has 6 replies, 4 voices, and was last updated 17 years, 6 months ago by
Mike_Javelin.
October 1, 2008 at 4:22 pm #39880
Mike_Javelin
ParticipantThe bearings on my rather old (more than 5 years) wma33 have given up.
Which I guess is not surprising with four kids etc.However money is tight and a new machine is not something we can jump too.
I’ve replaced bearings before in previous machines with some success but never tried on this hotpoint.
Access to the main shaft is ok and the nut and main wheel came off easily however is looks like the whole front of the machine will have to come off as the sides and back are all one piece.I’ve seen the bearing kits about and I’ve also seen reference to a “spider”
Is a new spider required as well as the bearing kit?
Do you have any advice other than the obvious “don’t do it”
Cheers
MikeOctober 1, 2008 at 5:33 pm #264003helo_75
Participantdepends
the front does come off
you need to take off the lid, the fascia
2 screws top of panel, 2 at bottom
the drom suspension pins will come out if you depess the pip and pull out the pinun hook the door seal and remove the weights
the drum will then come outits not a bad job.. just time consuming, a spider isnt always necessary
theres 2 bearing kits as well, 35 and 30mm, ull need to measure the shaft size
much better machine than anything hotpoint churn out now, so well worth it
and id be writin the wiring down as wee, so you dont get caught out
and, of course, plug out!!!!
good luck
October 1, 2008 at 5:33 pm #264004smartin
ParticipantRe: Hotpoint WMA33 bearing
you wont be able to tell if you need a spider until you have taken it apart
October 1, 2008 at 7:52 pm #264005Mike_Javelin
Many thanks for the advice, I’ll have a crack at it tomorrow and see how I get on.
The way I see it is I’ve little to lose in at least trying.
Thanks again.
BTW, plug came out days ago 😀
October 1, 2008 at 8:42 pm #264006iadom
ModeratorRe: Hotpoint WMA33 bearing
If its over 5 years old it will be 99.9{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain to have the 35mm bearings and not the smaller 30mm ones.
October 7, 2008 at 6:15 pm #264007Mike_Javelin
Bought the spider, seal and bearings from Whitegoods and they arrived today.
When I removed the old bearing, which was in a right state, I also retrieved a large spring that sat between the large bearing and the seal.
Having inserted the bearing there appears to be little room to fit the spring in the same position.I guess it might push into the seal when I drift it home but I just thought I’d check here before I bugger the seal doing something I needn’t.
Cheers
October 7, 2008 at 6:31 pm #264008iadom
Throw the spring away, its part of the old style seal that caused the failure in the first place.
