Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WMA34 heating element location
- This topic has 13 replies, 3 voices, and was last updated 11 years, 2 months ago by
Willholmania.
January 13, 2015 at 12:02 pm #83722
Willholmania
ParticipantHi. Could you please tell me whether I access this from the front of the machine or the back?
January 13, 2015 at 12:56 pm #423549electrofix
ModeratorRe: Hotpoint WMA34 heating element location
rear
January 13, 2015 at 1:17 pm #423550Willholmania
ParticipantRe: Hotpoint WMA34 heating element location
Thanks Dave.
January 13, 2015 at 4:43 pm #423551Willholmania
ParticipantHotpoint WMA34 doesn’t heat water after new element
Thanks to Dave for telling me where to access the heating element on this machine. I replaced the heating element with a genuine part after the machine started tripping the RCD in my junction box. It no longer trips the RCD but neither does it heat the water. Any ideas as to why this might be? All the wires are connected correctly – I took a picture of them before I took the old element out.
January 13, 2015 at 5:43 pm #423552iadom
Merged topics, best to keep it to one thread or it get gets a bit messy.
Did you test the old heater first and if so did you find a fault on the old heater such as low insulation?
If the initial fault was not the heater but the wiring harness near the front concrete weight then moving the wires as you replaced the heater could explain why it now doesn’t trip.
it may well have damaged the main pcb though 🙁
January 13, 2015 at 6:53 pm #423553Willholmania
I tested the old element with a multimeter but have no means of placing it under any load. It tested fine at low voltage. I had a look at the wires near the concrete weight, having read about chaffing problems with them on this forum, but they all looked fine.
January 13, 2015 at 7:24 pm #423554iadom
Hmm, a megger is by far the best option for insulation testing but even a decent multimeter would show if the insulation was really poor on the heater. might be worth having a look at the pcb for signs of blown tracks.
How long did you leave it before deciding it wasn’t heating, it does take a while before the heater is switched on?
January 14, 2015 at 9:47 am #423555Willholmania
My wife reckons it hasn’t been heating the water for a while. So although I’ve stopped it tripping the RCD it still isn’t heating the water. And as it has a new element, that means something else is stopping it kicking in. It just washes everything cold.
What else could prevent the element from energising? Is it likely to be a board problem? I guess there’s a relay on there that controls it?
January 14, 2015 at 10:08 am #423556iadom
Not a common failure on these but I have seen it at least once in the past.
January 14, 2015 at 10:11 am #423557Willholmania
Is there any way of testing it?
January 14, 2015 at 11:06 am #423558iadom
Not really with a basic multimeter. you could send it to EMW who will test it for a small fee and also repair it if required.
January 14, 2015 at 2:59 pm #423559Willholmania
Thanks.
January 15, 2015 at 10:58 am #423560electrofix
the fault could also be the pressure switch as the Heater circuit goes through the switch to make sure the heater is turned off if the drum is empty
switch is small unit at back of the soap drawDave
January 15, 2015 at 12:52 pm #423561iadom
Senior moment, :clown: Dave is correct, the pressure switch on these does not control the eventual wash fill level, only the overfill level. first click of the switch is the control level which allows the heater to come on, the rest of the fill is timed.
Pressure switch part No: is C00201957.
