Hotpoint WMA34P
  • #48495
    jackster
    Hi all. I have got the above model wm in my worksop as we speak with what was originally a dodgy motor. I have replaced the motor and all is well on that front, unfortunateley it now doesnt want to drain. If I put it on a spin it spins ok but there is no drain, I replaced the pump but still no joy. I am getting 58v to the pump which leads me to suspect the main board. I have also been getting the wash & end led’s flashing whicj I assume is a fault code? Please forgive me It is the first time I have worked on these WM machines. Anyone help?
    #296746
    Re: Hotpoint WMA34P
    Have you looked through the fault codes thread on this forum? Yes it does sound like a fault on the module. If it’s already had a new motor it looks like even a recon. board would bring your bill into BER territory. 🙁
    #296747
    jackster
    Re: Hotpoint WMA34P
    Got it sorted! It was the PCB, luckily I had one a scrapper of the same model and it worked a treat. Cheers all.
    #296748
    jackster
    Re: Hotpoint WMA34P
    jackster wrote:Got it sorted! It was the PCB, luckily I had one a scrapper of the same model and it worked a treat. Cheers all.
    Or so I thought! It is working fine until the final spin then stops, If I select spin manually it spins great? Any Ideas?
