hotpoint WMA34s
  • #61856
    cornflakes
    no action when programmed
    door lock light flashing and selected programme light illuminated
    seem to think i did repair similar,,brushes where at fault
    is this the same problem
    thanks
    Graham
    #347872
    Re: hotpoint WMA34s
    More likely to be doorlock shorted and damaged PCB. Could be door latch spring if you are very lucky.
    Have you done a visual on the PCB?
    #347873
    cornflakes
    Re: hotpoint WMA34s
    thanks for that
    will check out pcb and door lock
