Hotpoint Wma35
  • #45624
    waters
    Customer says that when they press start ,all the lights come on and it fills and drains at the same time,any ideas
    #286378
    Re: Hotpoint Wma35
    Check wiring harness near the lower concrete balance weight then run the last error detected routine listed in the Known Error Codes thread.
    Could be a faulty pressure switch, failing that its likely to be the PCB but not a fault I have encountered on WMA machines.
