Hotpoint WMA35 Confused
  • #56628
    maltheviking
    Now here’s one for all you Hotpoint experts πŸ˜‰
    WMA35, fitted a new door seal on Monday, checked and tested it all OK
    First wash by customer worked ok, next wash select any programme and machine goes straight into rinse and spin only, no door closed light on but door locked ok.
    This is where I come in again. Sure enough as customer says only does rinse and spin.
    I put it through the test prog . and a component test all ok πŸ˜•
    Next I checked to see if the board was configured correctly, as it was. Still no wash. My immediate thought was that the board was corrupted so I attempted to re-configure the board with no success. I attempted this five times before it allowed me to re-configure:?
    Put the maching on wash, now work fine.
    I had previously repaired the board after the wiring loom had “chafed” but that was a couple of years ago
    Now I thought I new these buggers inside out but this one has completely stumped me 😳 Any ideas peeps?
    #328164
    Allsorts
    Re: Hotpoint WMA35 Confused
    Check for bad soulder or dry joints in the areas that you repaired before.
    George
    #328165
    maltheviking
    Allsorts wrote:Check for bad soulder or dry joints in the areas that you repaired before.
    GeorgeDone every inch of the PCB with a magnifying glass, only PCB track damage previously, soldered up beautifully if I do say so myself :rolls: πŸ˜†
    #328166
    Time to stuff the PCB into a jiffy bag and get Tony to suss it for you Mal. πŸ’‘
    #328167
    maltheviking
    Martin wrote:Time to stuff the PCB into a jiffy bag and get Tony to suss it for you Mal. πŸ’‘
    No need martin, the machines working perfectly now, I am just confused why it took several attempts to programme the sod
    #328168
    maltheviking wrote:No need martin, the machines working perfectly now, I am just confused why it took several attempts to programme the sod
    “The sod” you refer to is feminine don’t forget and it takes time and patience to get a female under control as well you know. 8)
    #328169
    maltheviking
    Martin wrote:
    “The sod” you refer to is feminine it takes time and patience to get a female under control as well you know. 8)
    Do I actually believe that you have cracked the question that men have looking for from the beginning of time, if so :worthy:
    #328170
    philfish
    If that’s the case i need lessons of martin.
    Every time i even get close to trying to understanding my other half let alone controlling her she does not just move the goal posts she changes the bl{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}dy game completely!!!!
    All hale martin :worthy: :worthy:
    Phil
    #328171
    Well there you go, you live and learn eh Mal? πŸ˜‰
    You did mention that you “re-configured the board” but clearly that was a typo error you made and should have read “re-configured the bird”. It’s all down to knowing which buttons to press on them that’s all…. 8)
    #328172
    maltheviking
    Only button that’s she’s interested in is the one one on my wallet :snigger:
    Washing machine’s definitely a cheaper option
