Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WMA35 did I mess it up?
- This topic has 8 replies, 3 voices, and was last updated 19 years, 5 months ago by
n9eav.
November 12, 2006 at 7:49 am #22477
n9eav
Participant🙁 My Hotpoint WMA35 is about 5 years old. I could have had the £90 repair done, but they messed us about so much and did not arrive for the scheduled appointment. Anyway I decided to tackle the drum bearing job myself. I am quite hand but I do have a habit of making the odd mistake.
I managed to pull the whole thing appart and replace the drum bearings, thanks to a VCD manual I got from E-bay. I put it all back together, but…… I forgot where the wires went on the control board. Most can’t go anywhere but where they are assigned. However there are 3 pairs of wire in blocks that could be anywhere.
One pair is double red, one is double black and the other is blue and black. I tried putting them where I thought, but the machine did not do things, like pump, or spin.So 1. Have I broken the ciurcuit board control by putting the wires in the wrong place?
2. Where should they go? I see the board is marked with things like x5 x11 etc.
3. Predominantly the machine refuses to spin. It will trun on cycle and it will pump (depending on where I put those wires)
What a mess. Should have called out the expert. But I did think that my bearing job was not bad for an amateur, but like I said I do make silly mistakes….. Help?November 12, 2006 at 8:18 am #195128Martin
ParticipantRe: Hotpoint WMA35 did I mess it up?
n9eav wrote:Have I broken the ciurcuit board control by putting the wires in the wrong place?
Very likely you have blown the pump triac on the board if you incorrectly switched the 2 Blacks for the 2 Blue & Blacks then the boards a gonna! 😯
A new board is part number 1604321 and costs about £75 so not too bad if you don’t blow that one up that is?
(I know its crying over spilt milk and stuff but what a pity you never took up the 5 year parts warranty. Hotpoint would have put in a whole new modified drum unit. )
November 12, 2006 at 3:20 pm #195129n9eav
Thanks. I guess I got fed up with Hotpoint for never turning up. Oh well Unless anyone can offer any solution other than chuck it…… I guess a new washer is on the cards… what to buy?
November 13, 2006 at 6:09 am #195130n9eav
Shame to throw it away after all that work. But it’s too old to go investing in a new curcuit board. I mean the shaft looked a little beat up when I took it appart. Also there were 3 bolts missing on the three pronged thing at the back of the drum. Quality build for you!!!
So there must be someone out there with a broken WMA 35 or similar, or a second hand curcuit board… or one in a recycling depot??????
November 13, 2006 at 8:03 am #195131Martin
n9eav wrote:I mean the shaft looked a little beat up when I took it appart.
If you haven’t replaced the drum shaft your new bearings will fail in less than 6 months. The worn shaft is the sole reason the bearings failed anyway! 😥
November 13, 2006 at 11:08 am #195132iadom
ModeratorRe: Hotpoint WMA35 did I mess it up?
n9eav wrote: Also there were 3 bolts missing on the three pronged thing at the back of the drum. Quality build for you!!!
This is common and is not a fault, one bolt in each arm is enough, in fact you could say that two in each is over engineered, 😉 At a guess around 75{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the ones I see do have 6 bolts fitted. I replaced a drum support spider on a German made AEG last week that had corroded and snapped due to low temp washes with liquid detergents, that only has 3 securing bolts. The original water seal on the WMA model was badly designed, ( my guess is that Hotpoint did not actually design this seal) causing premature bearing failure, its replacement, the Rubena seal has been very reliable in comparison, the actual drum support spider used in these machines is one of the strongest in current use.Jim.
November 14, 2006 at 6:04 am #195133n9eav
Thanks for all your expert information and advice. It looks as though it’s best to move the thing on. Please will someone tell me I did a challenging job in replacing the bearing, even though I blew the rest of the circuits up
November 14, 2006 at 8:52 am #195134Martin
n9eav wrote:Please will someone tell me I did a challenging job in replacing the bearing, even though I blew the rest of the circuits up
Indeed you did and a lesson to us all, all the best! 🙂
November 15, 2006 at 6:06 am #195135n9eav
Now I feel better……… 🙁
