Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint WMA37 – Strange Problem…
- This topic has 4 replies, 3 voices, and was last updated 18 years, 5 months ago by
AviAero.
November 4, 2007 at 10:19 pm #31942
AviAero
ParticipantHi all,
I’ve got a Hotpoint WMA37N machine that’s recently developed a fault I haven’t been able to find info on anywhere.
When starting a cycle (any wash cycle), the drum will start to fill with water, as normal. Then, when it would normally turn the drum over a couple of times (presumably to get all the clothes wet), it instead spins up to high speed for a couple of seconds then stops abruptly. It does this a couple of times then goes silent and appears to just quit the programme – i.e. the ‘wash’ ‘rinse’ and ‘spin’ lights go on.
The water inlets seem fine, and the pump out works. I’ve also tried an empty load, same result. Any ideas? Like I said, I haven’t seen this mentioned elsewhere so any help welcomed!
Cheers
Avip.s. the machine is just over 5 years old so no chance of Hotpoint fixing it cheap.
November 4, 2007 at 11:23 pm #233024Penguin45
ParticipantRe: Hotpoint WMA37 – Strange Problem…
No speed control – computer shuts down the motor.
Remove front of machine and repair broken/chafed wiring around the concrete block is the usual solution. When finished, secure loom in such a way that there is no slack wiring flapping about under the drum, and that the excess is tucked into the corner of the casing.
I have to do this three of four times a week on the WMA range – very poor assembly from Hotpoint.
Power off, of course.
November 5, 2007 at 8:41 am #233025AviAero
Thanks Penguin – I’ll have a look at it tonight. Appreciate the advice!
Avi
November 6, 2007 at 9:52 am #233026AviAero
Update – just to let you know, the problem was due to chafed wiring. The loom between the motor and the motor connector had been catching on a support strut; I replaced a section of wire that had worn through, and all was well again.
Thanks again for your help! Just a thought, if this is a common problem would it be worth highlighting in a sticky/FAQ somewhere?
Cheers
AviNovember 6, 2007 at 10:45 am #233027iadom
ModeratorRe: Hotpoint WMA37 – Strange Problem…
TBH, If we posted sticky/FAQ’s on all common problems for all manufacturers it would run to a huge number of pages. :rolls:
The ‘Search’ facilty is the best compromise. 🙂
