Re: Hotpoint WMA40
Set-up for WMA40 only : –
With the Programme selector in the ‘Off’ position, press and hold the ‘Options buttons 2 & 3 whilst selecting ‘K’ on the programme selector and continue to hold for 5 seconds.
Options 2 & 3 LED’s should now be flashing. Now press the ‘Start/Reset’ button for 2 secs. All the LED’s will be extinguished to confirm the prog routine has begun.
Position the Programme selector to ‘B’.
Press ‘Start’ button briefly and the option 2 LED should light to confirm.
Now rotate the Prog selector to ‘E’.
Press ‘Start’ button briefly and the option 3 LED should light to confirm.
Now rotate the Prog selector to ‘Stop Change!’
Press ‘Start’ button briefly and option LED’s 2 & 3 should both light to confirm.
Now rotate the Prog selector knob to ‘D’.
Press ‘Start’ button briefly and option 2 LED flashes & option 3 LED stays on to confirm.
Now rotate the Prog selector ‘anti-clockwise’ back to ‘A’.
Finally, rotate the Prog selector switch ‘clockwise’ through all 15 positions starting with ‘A’ pausing briefly at each one whilst observing the ‘Final Spin’ LED. In the case of a WMA40 the Spin LED should only illuminate in the following positions: 1 –3 – 4 – 7 – 8 – 12 and 14
If the correct sequence of LED’s is observed, return the dial to the off position. If NOT then go over the configuration sequence again to get it right!
