hotpoint – wma40
  • #40369
    Minge
    Hi.
    I have this washing machine where once the door is closed and the start button pressed the door lock light flashes continuosly but doesnt lock/start the program… I have tried replacing the door lock but still the same problem… any ideas please?
    #265948
    Simon46
    Re: hotpoint – wma40
    Usually old lock has taken out PCB. unless door catch spring is weak.
    S.
    #265949
    Madmac
    Worth trying to repair blown tracks on pcb if you find any, sometimes get away with it. 😉
    #265950
    Madmac
    Oh, & check brushes!
    #265951
    Madmac
    No, forget that, im thinking of indesit boards, i need me lunch! 😉
    #265952
    grazzamongrel
    yep first look at door latch to make sure both springy bits are intact, then if they are okay then look at board for blown track where neutral from door lock terminates. if its blown it can be caused by a few things
    1. faulty door interlock
    2. check wiring going down to motor for signs of wear i.e. rubbing against front balance weight. this wiring loom also supplies the door lock so the replace the lot.
    you will see what i mean when you take the front panel off.
    HTH 🙂 🙂
