Hotpoint WMA42N door light flashing…
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint WMA42N door light flashing…
  • #67106
    washman3
    Hi all, i have a Hotpoint Aquarius wma42n with a flashing door light.
    if i select a wash,door light still flashes and also wash light. likewise if i select a spin cycle both lights flash. brushes are approx 50{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}
    is it possible i need a door lock mechanism?
    advice appreciated.
    #366309
    Allsorts
    Re: Hotpoint WMA42N door light flashing…
    The indications are that you need a door interlock… However, it is a trait of this version of machine that when the door interlock defaults it damages the control board… Advise would be to have the control board checked before buying parts.
    #366310
    Are you actually a bona fide trader washman3 ?
    If so then you really should apply for trade access, if not then you seem to be going through washing machines at an alarming rate. 😉
    #366311
    washman3
    Had actually checked the PCB in the meantime and found a burnt track corresponding with door interlock. i’m actually a dab hand at solder repair. damage is extremely slight. would repairing and fitting a new door interlock be recommended. Though machine is old in years its actually in mint condition and would be a shame to scrap. many thanks for your help.!
    P.S. would it be possible to PM you IADIOM re Trade Forums. i have read and understand the terms required.
    #366312
    If you are really lucky it may just have damaged the tracks but in most cases some component damage will have occurred, usually one of the very small triacs will have a tiny piece missing under very close inspection.
    If the rest of the machine is sound then send the PCB off to EMW if you can’t sort it, much cheaper than buying new and comes back to you with a longer warranty than a new one anyway.
    For trade access you need to follow THIS link then apply direct to admin@ukwhitegoods.co.uk 😉
    #366313
    washman3
    Many thanks for the advice. will try the repair,if its knackered i will be giving EMW a call.!!
    Shame that the PCB is the “fuse” on these machines.! 😕
    #366314
    And on Bosch, Zanussi, Hoover/Candy etc, etc. 😥
