Re: Hotpoint WMA44 Aquarius Extra Out of balance sensor
It is not possible to disable this function, there isn’t a ‘sensor’ as such, it relies on the control module sensing the variation in the load on the motor. The fault could lie in the motor or the control module. both fairly expensive. Best advice is to see if we have a local engineer in your area who can run the required diagnostics checks.
Also worth noting that if the machine is under 5 years old then it is covered by a manufacturers parts guarantee.
