Re: hotpoint wma44 wiring diagram
This should be ok for you…supplied to me by “Iadom” recently
Looking down on the back of the board from the top, working from right to left, its one plastic sheathed amp tag and one unsheathed amp tag, one white, square plug into selector switch, large conn block from motor/doorlock to X1, 6 pin block, valves to X5, blue/black, pump conn to X11, black/black, pressure switch to X9, red/red, ntc to X2 and if fitted the small conn to the facia variable controls to X4
