hi i am baffled by the fault on this machine so any ideas much appreciated.the machine washes fine then when it comes to rinse the best way i can describe is the drum rotates to quick causing water to come out through the dispenser drawer for a short time then it returns to its proper speed.i have replaced pcb with one from ecw but still have fault.
yes i am trade and currently in the process of applying for trade access.as for the fault i have i had tacho magnet come loose which i rectified and now during rinse the drum turns to quick for a short time causing water to come out the dispenser drawer,it then returns to normal rinse speed and is fine after that.
