Hotpoint WMA46P
  • #42796
    Does the “distribute in wash” thing as part of the programme and throws water out of the drawer. Occasionally a dribble, sometimes quite a lot. Machine is level, leaning back slightly, if anything.
    Any particular quirk I need to know about? Soap hose? Drawer/box?
    Re: Hotpoint WMA46P
    Not something I have seen except when machine has overfilled or been oversoaped. 😕
    geoffmackay
    Re: Hotpoint WMA46P
    Sump blocked maybe?
    Geoff
    #274953
    Re: Hotpoint WMA46P
    geoffmackay wrote:Sump blocked maybe?
    Something I would expect our feathered friend has already checked. 😉 😀
    #274954
    Re: Hotpoint WMA46P
    Hotpoint refer to it as a ‘surge wash speed’ and it speeds up from the normal 54rpm up to 90rpm for approx 3 minutes during cotton wash cycles only. 😉
    Leaking from the dispenser is usually a sign that either the soap hose is clogged or (and more likely) the air chamber/sump hose is gunged up allowing the machine to overfill slightly.
    Users of loose detergent in the soap drawer are the main offenders I find. 8)
