Hotpoint (WMA54 ,Aquarius)
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint (WMA54 ,Aquarius)
  • #30772
    diamondpack
    Hi, Hope someone can point me in the right direction, the problem is the washer will not go into the spin mode, it will finish the wash cycle and then the drum turns slowly but will not go at full speed. Its the same if you put it straight onto fast spin the drum just rotates slowly but not fast to take all water out from the machine. All other routines seem normal such as door lock and unlock clicks etc. All front LED seems functioning. Any blockage in the water out let cause problem or is there something more complicated that stopping it. Many thanks in anticipation
    #228360
    Re: Hotpoint (WMA54 ,Aquarius)
    Does the water discharge appear slow or restricted?
    Blocked sump filters are common on these and can give rise to this fault.
