Hotpoint WMA60 Fills then drains !
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WMA60 Fills then drains !
  • #69491
    gadgetdad
    Hi Guys, got a call for the above machine, filling then draining. Remember way back having one of theses which turned out to be the module and not worth doing – problem is its a fair drive from me and dont want to waste my diesel. Do you think its pcb or wiring problem ?
    Cheers
    gadget
    #374973
    Re: Hotpoint WMA60 Fills then drains !
    I have always found the electronics on the Ultima range to be quite reliable and have never encountered the type of fault you describe linked to the PCB.
    The machine does have a test routine, do you have that?
    gadgetdad wrote:Hi Guys, got a call for the above machine, filling then draining
    I wouldn’t mind betting that the customers report has been somewhat lost in translation and that all it really needs is a new set of brushes. 😉
    #374975
    gadgetdad
    Thanks for replies guys, yes could well be a communication problem – customer sounds about 90 !! two years older than me haha.
    Jim: Would appreciate the test routine please.
    gadget
    #374976
    PM me your e-mail address and I will send you the info.
    gadgetdad
    Just thought I would close this off – found broken wire on motor connector block – motor cut out I believe. All fixed.
