Re: Hotpoint WMA60P
Toni,
When a programme is selected and you press the start button, the first thing the machine should do is PUMP. It is normally energised for 5 seconds and then the machine should fill. Do check the pump out, it may be your trouble and the micro processor is going into error mode as a result. 😉
You can also perform a ‘Last Error Detected’ interrogation on those machines but that takes some explaining really and possibly I could help you on that if your stuck 🙂
Best of luck
