Hotpoint wma61
Viewing 15 posts - 1 through 15 (of 18 total)
  • #53015
    aclarke
    hi guys,
    got hpt wma61 fault is soon as turn on beeps and interlock sign flashes, changed interlock still same fault, checked wiring loom and wiring for motor and to pump etc all seems to give ok readings but still the same fault does this sound like pcb
    many thanx
    #314061
    franz
    Re: Hotpoint wma61
    Have you checked the spring in the door handle -if this is broken it will stop the door locking
    Franz
    #314062
    aclarke
    Re: Hotpoint wma61
    yes door handle fine just soon as turn on beeps all the time but checked everythin i can think of
    #314063
    Re: Hotpoint wma61
    Have you put it through a diagnostics test?
    I will send you the test routines.
    aclarke
    Re: Hotpoint wma61
    wont let me do that soon as turn on beeps none stop wont let u operate any part of it bloody digital rubbish lol
    #314065
    Re: Hotpoint wma61
    So it has to be the pcb then. EMW will provide a replacement at reasonable cost.
    Re: Hotpoint wma61
    I tried to send you the diagnostics but the e-mail in your profile is dead and it has bounced.
    Do you have a copy of the diagnostics routine?
    You have to unplug the machine and wait a ten or fifteen seconds before putting it into diagnostics. You have to hold certain buttons before you switch the mains on to get into diagnostic mode.
    If you can update your profile with a ‘live’ e-mail address I can send you the info.
    As for ‘digital rubbish’ the electronics on the WMA60 series are as good as any on the market, generally very reliable.
    aclarke
    Re: Hotpoint wma61
    finally got round to puttin this machine into diagnostics test never enough hours in day, and comes up with e17 replaced door interlock put still the same so am i right in thinking it be board fault
    #314068
    Allsorts
    Re: Hotpoint wma61
    Try the interlock again.. I just had the same fault on the machine and could not figure it out, so I tried the interlock again and it worked… Faulty interlock straight out of the bag.
    George
    #314069
    cornwell40
    Re: Hotpoint wma61
    Yup, I second that. Mind you it was a poor pattern one from Masterpart, the lock that needs bigger retainer screws.
    TC
    #314070
    lasty
    Re: Hotpoint wma61
    If it`s a board problem – Easy enough to sort if the damage is visible .
    There is a 3mm x 2mm chip on the bottom left hand side easily distinguished by three prongs out the top and a single square plate attatchment at the bottom all soldered . check the chip for blown surface damage and of course track damage . Repair track damage and change the chip with one off a scrap board …….
    usually sorts things out .
    #314071
    Re: Hotpoint wma61
    I also learned the hard way about Masterpart red plastic pattern locks.
    Mike.
    #314072
    gandh1
    Re: Hotpoint wma61
    Jim im putting 2x wma62’s together and wondered if that diagnostic manual is the same for what im working on. would love to be able to make sure everything on machine is working perfectly before i send it out
    #314073
    Re: Hotpoint wma61
    Its the same for most of the WMA Ulitima range, have sent you a copy.
    wilf
    Re: Hotpoint wma61
    checked the carbons?
    wilf
