Hotpoint WMA61P drum paddle which one do i need?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint WMA61P drum paddle which one do i need?
  • #35969
    boselecta
    Got the drum paddle with me it is the one where all the holes are the same. There is a space after the third hole from the front then all the spaces are even.
    I know there are three paddles but dont know which one to order, any ideas?
    serial no: 04863303
    #248901
    johnnyj
    Re: Hotpoint WMA61P drum paddle which one do i need?
    If all the holes are the same, there are 2 types one has 3 pips on the front of the paddle and this one is part n/o 1604464, the other has no pips and is 1603824 hope this helps. jj
    #248902
    Date code 04 – version 2 – 1603824
    boselecta
    will order 1603824 version 2 as no pips
    mercy becoup
    #248904
    bobokines
    on this subject. What’s the difference between version 2 and 3
    Bob
    #248905
    I’ve looked at them closely but the only difference I can see is the three small marks on the front of the mk3 and the replacement mk3’s are white. 😕
    I have also fitted Mk2’s in place of mk3’s and vice versa without any comebacks.
    hotpnt
    the sliding ‘lugs’ on the version 2 are square, version 3 are chamfered, you can squeeze a 2 into a 3 though
    #248907
    hotpnt wrote:the sliding ‘lugs’ on the version 2 are square, version 3 are chamfered, you can squeeze a 2 into a 3 though
    I will look a bit closer next time. 😆
    #248908
    Micky 32
    Had a call to replace drum paddles on a WMA the other day. I ask her for the model and serial so i’d know which paddles to bring. She lives 15 miles away. So i get there and the paddles don’t fit and i had the correct numbers etc so i couldn’t understand why they didnt fit ❓
    I then found out the drum was replaced under warranty so the hotpoint engineer fitted the newer type drum that uses version 2 lifters 😕
    Always a good idea to ask if the machine has had a drum job before you go to the house.
